- Feb 15, 2020
- Southern maine
- State - Country
- ME - USA
- Other
- 2023 2 door Big Bend, 2" lift, 35s.
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- Total Drop
- Shackle flip
- Tire Size
- 235/60/15
- My credo
- Its probably better to be self deprecating than self defecating.
How do you like it? I need a liner.
I will say that prep was easy enough and it applies well, and the little bit of texture is nice.
Other than that.. I don't have total confidence in the herculiner holding up long term for someone that REALLY uses the bed. I put on nearly the entire gallon, and I don't think the layer of herculiner is even 1/3 as thick as what you'd get from a professional coating.
If I were to DIY a bed again I'd probably go with Monstaliner. It comes in a bunch of colors which is cool, but you also mix catalyst into it.. supposed to stop the UV fade and leaves you with a much harder/tougher surface.
