- Apr 13, 2008
- Fort Lauderdale
- State - Country
- FL - USA
- Drive
- 2WD
- 3.0 V6
- Tire Size
- P235/75R15
- My credo
- A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
{I know the infamous throttle cable slack-over-time issue is not engine-specific, but didn't know where else to post it.}
BEFORE: Ancient OBD-II reader says idle position TPS reading is 14.9% (normal?), and mashed to the floor is only 87.0%... not good.
ANY-hoo, did NOT want to remove driver's seat, and finally figured out that 2 milk crates (and a couple layers of bubble-wrap for mah lower back over the door-sill) is the same height as my cab-floor, slid the seat all the way back, pulled the dome-light fuse (#26), and got after it... ended up getting 2 5mm ties and 2 3mm zips on there... that's a solid 5/8"!... and YET:
AFTER: Idle position TPS reading is still 14.9% (so I didn't OVER-do it), but WOT is increased to only 87.8%... WTF?
My 4WD XL-trim has the rubber flooring, but under that is a much thicker pre-formed layer of black rubber padding/soundproofing... seems to me this is preventing full pedal-travel... what say ye, RKIs???
PS: what "redline" (computer-limited) RPM should I see @ 100.0%/WOT??
