RobbieD
2.9l Mafia
- Aug 6, 2007
- Georgia
- My credo
- Toonces drives a Ranger . . . . just not very well.
....but I just want my back window the way it was.
If I did it myself it would be so its done right, not to save a buck.
I need advice on the best way to do this, not the cheapest.
I would start by getting a quote from a good auto glass and trim shop. It'll at least give you a gauge that your time and hassle can be measured against.
Another thing will be using OEM versus aftermarket parts. An NOS or salvaged slider assembly may be difficult to source and likely at a higher cost. In my own opinion, an aftermarket usually won't have the look, quality and "feel" as an OEM unit.
A big factor here, is that the older OEM sliding window units were designed to be serviceable, and the shop manual describes breaking it down to replace broken components, like a fixed glass pane. That's another reason I would suggest talking to a good glass shop. A good one should be able to tell you what your options are in getting it repaired.
If a good and professional glass guy can replace the broken pane on your old unit and R&R it with a warranty, at a reasonable cost (based versus YOUR time's cost), to me that would be the way to go.
Good luck with it.
