Non-Ethanol
helpme
Hotlanta
If you have it available, how often should you run a tankful? Thanks.
You don't have to if you are looking at is being some kind of system cleaner. If you are looking for something for that purpose, something like Techron fuel system cleaner would do the job but there is a catch for it to perform best. Dump a bottle of whatever cleaner you choose to use before you fill the tank to get a good mix and then run it until it is almost empty before you refuel it (fuel light comes on is good enough if the vehicle has one). I do this twice a year to make sure the injectors stay clean. It may clean other things but that is the primary purpose.
If the non-ethanol gas is readily available, is from a major brand, and the cost is close enough to negate the price penalty due to the slightly better mpg you will get (about 1-3 mpg roughly), then I'd run it as much as I can. The only "reasonably" priced non-ethanol gas near me (about a $1.00 per gallon more) is garbage gasoline. So, I don't run it. The next closest is about an hour away and the prices are outrageous. The cheapest they have is 93 octane and I think it was somewhere around $6.00 a gallon last I checked. No thank you!
I'd only use it for storage, but only short term. If you know you're not going to use it for a long time, drain the tank and protect it with something to keep if from rusting. There's a few ways to do that. Easiest would be to fill it with Diesel and then recover the Diesel before using it. IMO it's better to use a vehicle then let it sit too long.
Storing a vehicle with an empty tank might work in Florida but not here, when temps drop moisture will condense in the tank. I store my truck and Mustang with full tanks and a heavy dose of Marine Stabil. In the spring I drain 10 gallons or more out of the Mustang and replace it with fresh gas. My truck and Escape don't mind 6 month old 93 octane, the Mustang doesn't like it one bit. I tried running non ethanol in the Mustang but all I can get is 90 octane and I had to pull the timing back to run it.
All our gas should be non ethanol, it takes more energy to produce ethanol than it produces, my experience showed a 5%+ decrease in mileage with E10, and the smell of E10 coming through a cold catalytic convertor would make a buzzard puke. Not to mention the fuel system damage E10 does to anything carbureted.
+1 ^^^
Full tank is best
What degrades gasoline the most is contact with air, the "gasoline" hydrocarbons evaporate, why gasoline smells, the warmer it is the more you smell it
full tank = less contact with air so less evaporation
Yes, add a stabilizer and then drive vehicle until its warmed up, this will pull in the stabilizer to the fuel filter, fuel rail and injectors
Stop at the gas station and top it up
Park it
Unhook one battery cable
If it will be stored outside in cold temps pull the battery out and put in garage to avoid super low temps, also make sure Anti-freeze is not too old, lol
And just as a heads up, 87 octane fuel will degrade faster than 93 octane when exposed to air
87 octane has more "unstable" components than 93 octane, so will tend to "evaporate" faster and have higher "varnish" residue
We are talking 4 or 5 months here in an open container for 87 octane, and 9-10 months for 93 octane, with no stabilizer added
Or hook it to a battery tender, and have the tender itself under the hood, with the extension cord tied around something under the hood, so it can't be pulled out by some enterprising five finger discount artist. I've done that, and I live in an apartment. But, I sold my Mustang in November, so the Ranger now has a garage to hang out in. And yes, even with a tender, I still unhook the negative terminal if it is going to sit for a week or more.
i run it as often as i am in town when i need gas. the closest station is about 5 miles away that has it so i try to go to town for something when i am ready to get gas.
Florida is terrible for vehicles, both inside and out. I don't suggest storing any vehicle with an empty tank, unless it's in the SW desert or in climate controlled storage. I recommend draining the tank of gas and filling with Diesel or something like K1 that you use otherwise. IMO fuel stabilizers are snake oil. Gas is not meant to be stored, regardless of what's put into it. Diesel and other non volatile fuels can basically be stored indefinitely. I still think it's better to run the engine once a week or better yet drive it. Vehicles are not designed to be stored.
In 10-20 years you'll look back and say I didn't realize how good we had it now. The communists of the 13 familes/WEF don't want people to have energy sources they can't fully control all the time. They don't believe in freedom of travel for the masses. That's the real reason for the push to modern EVs, not environmental nonsense. They want to be able to remotely disable or limit the use of all vehicles at any time. They also want to control what you do in your homes when it comes to energy use.
...communists of the 13 familes/WEF don't want people to have energy sources they can't fully control
...reason for the push to modern EVs...to remotely disable or limit the use of all vehicles
...control what you do in your homes when it comes to energy
I store my three motorcycles all winter long with 93 octane and one ounce per gallon of Marvel Mystery Oil in them. In the Spring, all three start right up, no problemo.
beware of algae forming in hot weather, it likes diesel fuel.
Here in FL, it's readily available. I buy it for my zero-turn and all of my two-stroke outdoor equipment. l will run a tank through my truck when I take the gas cans to get filled. I can usually stockpile enough Kroger fuel points to get $1/off per gallon. There's no limit, so I can put 20 gallons in cans and another 20 gallons in my truck.
