Stuck in theft mode
Ohio
So I recently got a 1999 ford ranger super cab 3.0 flex fuel, computer had burnt spots so I found one same numbers in another ranger installed it now it says I'm stealing my truck it cranks away and doesn't start. Please help
If you are computer savvy, you could try this. I think if you apply for the extended license, you could program the PATS. You would need a laptop and buy a cable and then download the software.
so couldn't I just go to the same truck get the pats system ignition and keys with the cluster?
Yes you could, you would need the PATS module(above glove box) that is already paired(married) to the Computer you got from that same Ranger
Also need at least 1 PATS key for that Ranger and use it to pull out the ignition key cylinder as well, so you can put that in your Ranger so you can Start engine
Your current PATS keys won't be recognized by the new PATS module/Computer pair
If you want to pull the 2 door lock cylinders on the wrecking yard Ranger then you would have matched locks
I believe Forscan will allow you to pair a new PATS module to the ECM, but it's not something I've had a reason to confirm.
In Moparland security lockout is a dealer phone call.
Not sure how Ford's security system works though.
If its VIN based then theives must love that Mopar setup
"Hey I just bought this car, need the security code, here is the VIN", lol
Ford dealers do have key codes to cut new keys to unlock doors, but there is no record of PATS key's internal numbers needed to start engine
Even Remote Starts internal electronic key code needs to be programmed in like any new PATS key added
No, to make an appointment to have it towed in.
I have never used it myself. I have heard rumors it's a little hard to navigate. But it is free and seems to have a lot of power when it comes to Fords.
I've used it to wipe keys out of the system and start over with new ones. Just not to replace a PATS module.
I call it Forskin.
