Seems like a lot of these suggestions are what people would buy for doing work around their house.
It really depends on what your use case is. If you are charging people, you don't want to screw around, show up do the work as quickly and professionally as possible, and collect the check. You don't want to be monkey around with something cheap that "mostly does a good job" and they guy with the check book doesn't want to see that.
A lot of mobile welder will use 110v units simply because a lot of places don't have access to your truck or a 220v outlet. Like the basement of a hospital or the roof of a office building.
If you want to make money, show up with tools not toys.
If you want to weld your lawn mower back together, buy whatever you can get for cheap off craigslist that is close enough.
