- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
I was trying to match front splash guard bolts on the Lexus and I *think* they are M6.3-1.81 x 20mm. I already got some (not that exact size) that looked the same in the pack but threads are just enough different to not fit.
I do have one for an example to match, and my question here is, what's a good tool that will let me fit/try different sizes of bolts/threads so I can determine what it is, and/or try prospective ones against it. Advance has tests for some sizes but they are just for common plus I'd like to have one in my shop anyway. If they're not horrible expensive.
6.3mm sounds like 1/4" to me but I guess it's not. Heads are 10mm.
The example oem one I have goes in fine in the empty holes (threads take fine). The wrong ones I got, start ok, but fairly quickly seize up and to me that says wrong thread, just off by a tiny bit, which is enough. If it binds with finger pressure, I stop there and regroup.
I run into this kind of thing not often but periodically, enough to make me want to be able to measure it and say for sure "it's this size".
