My truck has been idling really rough since I got it, I've replaced just about every single sensor there is on this truck except for the TPS. After replacing all that, I decided to test for vacuum leaks and I saw a leak from the lower intake manifold gasket and the pcv valve. Replaced both gaskets and the breather gasket on the right too, now it runs even worse. Both then and now, it runs so rough the engine shakes bad at random times. I'm not even 100% sure how to set the timing because there's a hole but also an almost arrow looking metal piece pointing on the markings on the harmonic balancer so I'm not sure if the timing is right. It idle surged rarely before, but now its an extremely bad idle surge to the point where I have to hold the brakes to stop myself from slamming into the back of the garage. It's also varying the RPMs all over the place as it feels like. It would idle high but then go down to the point where its struggling to stay running without me touching the gas pedal at all. I've been fighting this truck for the past year and I'm so sick of it. I can't figure out what's causing these things.
