- Mar 6, 2020
- State - Country
- MI - USA
- Vehicle
- Ford Ranger
- 4.0 V6
- Total Lift
- 1-1/2 inch front leveling
- Total Drop
- Stock
- Tire Size
- 31/10.50/15
- My credo
- What's the worst that could happen?
I know the difference between regular gas and recreational gas and what it is supposed to be used for, but would like your opinions.
I have a 72 Ford 5000 tractor. I normally use regular gas. Not sure of the ethanol content. It runs fine or did until last summer. It would start fine and run for about a half hour, then stall. It would start up again, but stall immediately. If I waited a while, it would start and run for about a half and the process would repeat. Son-in-law suggested the gas was bad and that I should use rec gas. I drained the tank (about 7 gallons) and replaced it with a couple of gallons of rec gas ( didn't want to use too much in case I had to drain it again. Started and ran it for about an hour dragging in some felled trees for firewood and it ran good.
While I agree that the gas could have been bad, I'm not sure about the use of recreational gas. Does regular gas have a shorter tank life than rec gas or something like that? What's your take on it.
Thanks.
Thanks.
