- Jan 28, 2023
- Brooklyn Park, MN
Brooklyn Park, MN
7’ box rust free $300
Thank You
I need the sheet metal that is under the driver seat, and the curved front part in the door jam (rocker panel) for both sides.Well I have 2 extra cabs. What pieces do you need?
Well I wouldn’t want to cut this repaired rust free cab and my other one, the parts you need are junk. But you can get what you need here.I need the sheet metal that is under the driver seat, and the curved front part in the door jam (rocker panel) for both sides.
I checked LMC they don't have it. they have the door skin patch and the floor pan, I do not need those. I need the rear floor section and the front "U" rocker panel door jam section that no one sells.Well I wouldn’t want to cut this repaired rust free cab and my other one, the parts you need are junk. But you can get what you need here.
probably better and cheaper.![]()
Inner Body Steel and Patch Panels
Shop our inner body steel and patch panels for Ford Ranger 1983-2011, Ford Bronco II 1984-90. Perfect for maintenance and care.www.lmctruck.com
I’ll check my rusted cab again and see if those portions are worth cutting out tomorrow.I checked LMC they don't have it. they have the door skin patch and the floor pan, I do not need those. I need the rear floor section and the front "U" rocker panel door jam section that no one sells.![]()
Thank you so much, really I have been hunting these parts down for awhile.I’ll check my rusted cab again and see if those portions are worth cutting out tomorrow.
