- Nov 26, 2013
- Sonoran Desert
Howdy everyone!
While swapping the stock 7.5 axle for an 8.8, I dc'ed the flex line to the Y-fitting by the pumpkin from the hardline that runs along the frame from the front.
To stop the dripping, as I've done lots before with no issues, I put in a bamboo skewer (like for grilling) to temporarily plug it. Well, apparently these are skinnier skewers than I've used in the past and it went in the line itself, to the first minor bend (not the 90), about 1.5 inches up. Still no plugging.
Pulled and it broke off right there, about an inch of bamboo, maybe 3/8 of an inch from the end of the hardline. (if you know how rigid those skewers usually are, you wouldn't expect it to break)
So far I've tried to remove it with a drywall screw, skinny tweezers (not skinny enough), and those pseudo dental picks from Harbor Freight (which bend on bamboo btw). The picks got a few pieces of fiber separated from the lodged piece but no moving it, either direction.
Oh yes...I started with a good, hard stomp on the brake pedal. Quite the mess but no dislodging. The line did drain all the way and was dripping the whole time I messed with it Friday.
I'm tempted to leave it until I get a problem down the road (no pun intended) with the rear brakes.
Any suggestions for removing it (beyond replacing the line and "Don't do that again.")?
Thanks in advance!
Jon
P.S. I see Eastwood has an Aerosol Injected Cleaner that is supposed to blow out clogged fuel and brake lines, but the line still drains. Not sure how effective it would be. I also am contemplating using bailing/tie wire as a type of ram rod from the front, to see if I can push it out.
"And that's how the line became clogged with bamboo, steel wire, and caulking."
Thanks in advance!
Jon
