Get a helper. While you have your meter directly on the battery posts, have someone crank it over. If the voltage on the battery drops really low, it's no good. If it stays up rather high, then you have a problem somewhere else. While they are cranking look for smoke or feel for a hot connection on the large wires to the starter relay and the starter. Fat ground wire also.
