1991 4x4 Ranger Disc Brakes
Bigtimmyt
EMT / Paramedic
Firefighter
Stuart, FL
I’m going to replace my front brakes soon and replace my wheel bearings while I’m at it. Does anyone have a part number for the inner and outer bearings? There are a lot to choose from at Rock Auto.
You need to determine what front axle type you have. If you have the 4.0, then more than likely you have the larger front axle. If the truck is all original.
Inner and Outer bearings are same.
Dana 28 - Timken LM501349 Hubs are ~2-1/2"
Dana 35 - Timken LM603011 Hubs are ~2-13/16"
You just just need to figure out which axle you have.
Assuming stock anything newer than mid year '90 is a Dana 35 no matter the engine, 4.0L changes the rear axle mostly
