Junk Collector
⭐Supporting Member
Truck of Month
Need input from a plumber, anyone on here?
Have lived in my house for 7 years. Water heater (natural gas unit) replaced in '15 when I bought it because it was leaking. It leaked again around the bottom of the tank in 2018 and was replaced under warranty. Now, I am having issues throughout the house with really low hot water pressure (cold is fine.) Additionally, the latest water heater is dripping out of the pressure relief valve - probably about a quart a week or so for the last month.
I have drained and flushed it a couple times as I hear that sediment can build up and plug the hot side. Thus far that has not helped the pressure issue, but it is no longer making popping noises when the burner is running so I guess that's an improvement.
Any ideas? Rather not replace the whole thing if I can avoid it. Richmond water heaters seem to be junk.
