Seeking L&L style relocator 351/302
Angie
Vancouver area BC Canada
92 & 83 project
Hey all, my 351 C build has been on hold now for some time..... I am seeking the clockable oil re-locator as the one i was trying to get to work will not allow the proper angle for the hoses to be attached.
does anyone have a clockable one sitting on a bench that they will never use and are willing to sell?
or know of a different place where I can buy a new one that is like this? another company making them?
cheers
I think I posted the wrong one. You need a 3/4-16 thread? That would be Derale 15746 Your engine took a PH8A style filter? It's 3/4-16 thread.
hi, i have 1 on there that is close to the same thing. when the adaptor is tightened to the block, the oil lines are pointing into the wrong places for attaching. the style i am seeking has a main bolt that goes through the adaptor allowing it to be placed and then tightened allowing the oil hoses to be swung out of the way for the block.
cheers and thanks
The picture is like the one I used- and I regret it. There's another one that is held in place by a through bolt so you can position it where you want and tighten it down. I have to remove the hoses, which usually means cutting them, then unscrew the adapter. If I can find the bolt on adapter again I'll post it- after I order myself one.
I used one like the picture. It does the thing, I tried to remove it to see if I could fit a hardmount out of an Explorer (I think I could) but it will not unscrew without first removing the engine mount. I wasn't that dedicated...
hi walt. the 1 you are asking about is the same 1 i am seeking. click on the link on the top link i posted to. it should open to what i am seeking. I have been in contact with them over last few months and they do not have any in stock nor said when they will have any new ones for sale. hence why i started this thread.
cheers
How about this one: Amazon says they have 8 in stock.
Moroso - 23682 Remote Oil Filter Adapter
thanks walt. yes that is the creature i have been hunting. they are multi directional to be secured in any location. I will look deeper into Moroso now.
CHEERS thanks
CHEERS thanks
Christmas is coming and I want one, too. Just saying.....
Hi Angie. I have that Moroso that I did not use because I chopped the frame for a K member to hold my C . Let me know if you'd like to buy mine - "never installed" or used.
