- Aug 6, 2007
- Age
- 63
Hello everyone!
I'm NOT happy about having to choose between two forums and would far prefer that people in higher positions work their differences out like men.
Aside from this, my bi-annual emissions test is coming up. I've been running the same plug wires for three or four years now, and with the MESS I'd made of my coil wiring because of the misinformation concerning DIS with Megasquirt, (
) I decided to repair the coil wiring, swap plug wires, change the spark plugs and check everything else out.
I've uncovered several issues. The first is that the nebulous intake tube that I've fashioned (which consists of a 90 degree rubber plumbing elbow fitted internally with aluminum tubing cut to keep it structurally sound under vacuum) has failed. One of the aluminum pieces tumbled through the intake tube and actually got jammed into the factory throttle plate actuator shaft. (I've long since removed the throttle plate, but the shaft that's connected to the throttle cable remains in place, and obviously that's a GOOD thing!) Also, the rubber plug I'd inserted into the PCV fitting on the bottom of the non-functioning throttle body has worn out. I had a bit of a vacuum leak there, so THAT had to be replaced.
I took off the upper intake manifold, cleaned out the EGR passage (which wasn't really that dirty) and applied vacuum to its control valve to verify function. I also removed and replaced the spark plugs on the driver's side, where I discovered that the #3 plug had been sitting in a pile of rusty sludge. The plug electrode was white on that side, but looked normal on the other half of the head.
I cleaned all of that out, but it's clear that I'll need to keep an eye on that #3 cylinder . . .
With new wires, plugs in all holes and repaired vacuum leaks the engine runs really well. (It wasn't running badly before, but this will be my first time through an emissions test with Megasquirt, so I have to do this right!) I've got to re-set my TPS value, though, because the cable had stretched and I tightened it up. Therefore, it wants to idle higher than it should and the overrun cutoff is acting a little funny.
I also wanted to recalibrate my O2 sensor, but I can't get it out of the exhaust! (Bad words . . . )
I STILL don't have the blower reconnected because I've had a few set backs. With time my bracketry had bent out of alignment, so I had a plate with slots welded onto the back blower mount. In this way I can adjust the plane of the blower pulley relative to those of the engine, but the M90 has a "hump" on its belly that raises the entire blower up a couple of centimeters. I'll have to get that plate partially cut out so I can get the blower mounted properly.
Also, the friend who was supposed to fabricate a throttle cable mount for me has been too busy to do it. I have a collection of mandrel bent 2.25 inch intake tubing that will have to be cut to fit, and I still have to figure out how to plumb the bypass valve in. Hopefully these issues will be resolved soon, but as usual, money is tight, so I just can't go to a fabricating shop and have the work done for me.
Why didn't I take metal work in high school???
robert
robert
