Did you count splines on an axle shaft? Many of the original Thorsen LS diffs got replaced in the recall. Many were replaced with open carriers. Maybe that one got replaced with what you have? Disappointing to not have the Thorsen. But if you have the 31 spline shafts and got an LS carrier anyway, I’d call that “pretty good”.
I thought those 2 years (02&03) were the only years that Rangers had 31 spline 8.8’s.
Maybe I need to go back and review that.
Correct me if I'm wrong, but if you've got the cover off but haven't pulled the shafts yet, can't you quickly identify 28 vs. 31-spline by measuring the width of the crosspin? IIRC they should be 3/4" vs. 7/8", respectively.
Yes. I just reread the tech article. I was mixed up on that.After 03 they have to be FX4 level2 to have 31splines is how I understand it
Here is the tube diameter info
Axle Tube Diameters:
- The 1990-2009 Ford Ranger 28-spline 8.8-Inch axle tube is 2.80 inches in diameter.
- The 2010-2011 Ford Ranger 28-spline 8.8-Inch axle tube is 3.25 inches in diameter.
- The Ford Ranger 31-spline 8.8-Inch axle tube is 3.25 inches in diameter.
- The Ford Explorer 31-spline 8.8-Inch axle tube is 3.25 inches in diameter.
- The Ford F-150 / Bronco 31-spline 8.8-Inch axle tube is 3.25 inches in diameter.
- The Ford Mustang 8.8-Inch Axle tube is 2.80 inches in diameter.
The circumference you reported doesn't line up well with either axle diameter, mathematically.I’m getting up early and heading straight to my shop to measure tubes and Cross pin. If a truck clearly said level2 and the yard listed it as a “level2” axle I have reason to be salty right?
Axle tubes neck down twice, cross pin is 3/4”, and the splines are 28.
junk yard wants the axle back and I have to pay shipping which will be $200-$300 so I think I’ll keep it for now. It gets me into 4.10s and something other than an open carrier, the brakes look almost new, and in general the axle looks to be extremely low mile.
Ill just keep looking for my unicorn but only consider things in driving distance and look at them before buying, can’t trust anyone.
