- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
215/75R15SL OWL All terrain was the stock 4x4 tire
on the XLT if you got group 867A (I have that) you'd get 235/75R15SL OWL A/T and that's what I have on right now
optional on XLT was 265/75SL OWL A/T
so I can put on the optional tire, it'll be fine, and it'll still be OEM and who knows it might have had those to start out with I don't have the door tag so I don't know
I am trying to get the sticker for it
this puzzles me: 265/75R15 have diameter 30.7 (so it's basically a 31" tire) and when you go to 235 or 215 that's quite a difference and I'm wondering if they just let the speedo be a little different for them all or did they put a different speedo gear or what? let's say mine is calibrated to 235, and I go 265, it's about 3% different diameter so my speedo would read just a bit low, probably not enough to worry about.
I'm thinking they either used different gears or chose for the most common.
Toyo Open Country A/T III | P265/75R15 (tirerack.com) would be an example of something OEM size
if I go to 31" I think the selection is greater even though those sizes are not appreciably different (265/75 vs 31x10.5). 31 wouldn't have been offered as OEM though.
I'm not saying Toyo is good tires I don't know but I do see it says it's good in snow so for me that would be a plus and it looks pretty aggressive for off road
The more aggressive treads will have a little more road noise I think. The Cooper Discover RTX's that are on there now are quiet, but they're probably a bit less aggressive than I want.
And I'm checking the other tire recommends/un-recommends already made. Thanks.
