In search of some old steel ranger rims
RustyDusty
Forum Member
California
I'm getting ready to put some new tires on my 1987 4x4 ranger but I've been wanting different rims on the truck and now would be a good time to source them so the new tires can go on those. I'm in search of something similar to these rims I found on an old first gen ranger I saw online.
Are these basically just old ford steelies from something like a mustang or are they trailer rims? Anyone have any ideas on my options when it comes to searching the local classifieds for rims? There's a lot of 5x4.5 bolt pattern rims but I'm not sure about fitting them over my 4x4 hubs. Would these old 5x4.5 1950's ford rims someones selling near me work?
Also, if anyone has any tips on a good tire size for a first gen 4x4 ranger after a 4" suspension lift I'm all ears. Based on the chart I found on this website I should be looking for some 31" tires if I don't want any rubbing without doing some modifications to the body.
Those wheels in your first picture were a factory option in the 80's. Early 80s, to be exact....... I would go junkyard hunting and see if you can find some. They were often used for the spare tire. That exact style is kinda hard to find, though, I've had probably 30-40 Ranger pickups over the years and only saw a few of those. I can't tell if the ones in your second picture would work. It appears that the center of those wheels is offset further towards the outside of the wheel, meaning that your wheel & tire would sit further inside your wheel wells. Jeep wheels are like that and IMO it looks kinda weird.
As far as tire size goes, it depends on the wheels you run. Factory wheels should be able to clear 31x10.5s without rubbing with your 4" lift. Wider wheels or those with negative offsets/less backspacing may be a problem because it pushes the wheel and tire out further. You could also look at 16" wheels & tires, or narrow tires as well... used to be able to get 31x9.50's in a 15" size that were nice and narrow.
Thanks for the response. Thats too bad those rims are hard to find, the stock ones on my Econoline look just like those and I really like them. I will look around at the junkyard. I do like the looks of a narrower off road tire personally.
i saw some on facebook market place here in south texas. every time i see them, i picture the old 85 ranger my dad had as a company truck.
i cannot find the ad for the whole set
Interesting so they're 14" rims, That makes me reconsider wanting to get some, I feel like it would be easier finding tires for 15" wheels right? How are you able to ID those rims as the ones on the truck I posted? All those old ford steelies look real similar to me.
Check hotrod shops like Summit, Jegs, Speedway etc, people are still making them.
I would not spend any money putting 14" wheels on a 4wd, especially a lifted one. Finding tires will be a nightmare.
The spare tire wheel on my 1990 BII is that style (and is 15x6" w/3.75" backspace). I don't think I've seen that style offered as the regular road wheels though, you'll probably have to scour the junkyards for spare tires from every Ranger and BII you can find.
Interesting that this style was mainly used for the spares. I'm not going to obsess over getting a full set if they're that tricky to find. I was hoping they were a lot easier to find a full set.
Same here. I'm pretty sure I've only seen that style of "4 spoke" (or 4 slot) wheels as spares. The 4 spoke road wheels were styled different.
Picture from an early Ford sales brochure, these are the steel (road) wheel styles used on early Rangers and Bronco II's:
The "4 spoke" steelie on the left was used on 1983 to 1987 trucks, Rangers and the Bronco II, in 14" and 15" (the B2 was 15" only, I believe).
The 8 spoke steelie on the right was much more common, and came in 15" and 14". It could use a chrome trim ring, as shown here. This style was used on '83 to '91 Rangers, 1984-'90 Bronco II and '91-'92 Explorer (later two, as 15").
I don't know what styles or sizes that any of the other Ford models used (i.e.- Aerostar, F series, etc.), and I think that the Ranger bolt pattern was kind of unique.
Actually the ranger pattern is kind of commonish in Ford land. Last I knew the mustang is still using it.
The 5 on 4-1/2 pattern is also very common on trailers, Ive seen plain rims like that on many boat trailers.
Would it be safe to run trailer rims like that on a truck? I see people advertising 5x4.5 trailer rims for sale that look a lot like the ones in the original pic I sent but Im unsure if its kosher to run those on a ranger.
