I’m going to install a 8.8 rear end on my 1983 ford ranger and a Dana 35 front end, I have the 2.8l with 35s, now I am going to go with the 5.13 gears, but what all do I need to buy to regear both axles to make everything work.
He painted the heck out of the gear. That seems a little excessive
What size splines would I need I want to do the grizzly locker with 31 splines, any suggestions?
You can get custom 31 spline axles with 1.4" bearing surfaces which fit in standard 8.8 housing. @4x4junkie has a set I believe. (But you're correct about the standard axles).The 31 spline axles won't fit the standard 8.8 housing in a Ranger.
You'll need the 8.8 from an Explorer or if you're really lucky you can find a housing from a FX4 Ranger with the Torsen limited slip to get 31 spline.
