Decode Door Sticker
Garth Libre
Forum Member
Tennessee
I have a Ranger 2010 with an R in the TR section on the bottom. I can't find an R listed in the decoder. What does R signify?
"R" was a late comer on the Rangers, means 5R55W automatic, only found in some 4.0l SOHC Rangers after 2002
Used more in Explorers with 4.0l SOHC
It may or may not have a dipstick
If no dipstick then there is a fill/drain fitting in the pan
"W" designation means gear ratios were "wider" than the "E" model, 5R55E
Then my Ranger must have a replacement door because it was clearly the 2.3 liter manual transmission.
The sticker should have a VIN on it. You can check it against the truck's VIN plate.
1993 and up Manuals used "M" for the M5OD-R1 5-speed manual, 2001 and up 4.0l SOHC used "J" for the M5OD-R1HD manual trans
