What do you hate about your Ranger?
I honestly cant point to anything i hate about any of my vehicles except the cobalt.
Well, now, I think I can guess what you hate about the Cobalt:
  1. It doesn't have a 2.9
  2. It's Front Wheel Drive
  3. It's not a real truck because it doesn't have:
    1. An 8 foot bed
    2. Solid axles
    3. A V-8 engine
    4. a regular cab
  4. It's not a Ford
  5. It's not a Dodge
Did I miss anything?
I hate that it had major issues that forced me to take it off the road.
I hate that it would have cost more to fix than the truck was worth.
How would you tighten a rear window? Not too sure where the bolt is on the door you’re referring to. I’ll try anything once I know how to do it.
Early on all extended cabs had a bolt in rear window and regular cabs were held in by the gasket but with the cab redesign in '98 all rear windows use the bolt in extended cab window but it's the same window used in extended cabs from '86 on... there's 8 little nuts on studs (that take a 9mm wrench) that hold the window in, the window is just sealed with some butyl rope ($16 at autozone last I bought some). Yes, all that is behind the window trim.
The nut I was referring to in the door, if you pull the door panel (T27 for the window crank, screw for the door pull and door handle and I think one more somewhere then lift up). Then peel back the vapor barrier thing and you'll see a channel in the middle of the door, there's a nut on the top of it, while there check all the fasteners for the window tracks, there's one in the front and one in the back.
    1. An 8 foot bed
    2. Solid axles
    3. A V-8 engine
    4. a regular cab
  4. It's not a Ford
  5. It's not a Dodge
Actually yeah the reason i hate it is what you missed.
Its nutless as hell.
I hate that I sold my 83 XLT back in 2002 when I was moving down to MD.
I hated the PVHs on the 98, but easy fix with the manual hubs, I hate the frame rust on the 98 but helped my welding skills a great deal. Guess I'm more of an optimist than I thought...
I dont like torsion bars but that is not specific to the ranger. I didnt like them on my frontier, either
I hate that after spending many hours cleaning, it can still stink like cigarettes from the previous owner.
Hate I don't have time to address that and other issues.
Can one take the upholstery off the seats and throw them in the washing machine?
What is the best way to wash them? Should one line dry them?
I’ve never done it. A buddy of mine washed his. All I know is it came out good.
He’s a member here, but hasn’t been on in long enough that it won’t let me tag him. @steev
What do you you hate about the cobalt? I was sort of into the SS version.
The fact its nutless lol. Other then that its not bad. But it does get 30mpg so that kinda cancels it out. Its just a base 4 dr, even has manual windows and locks and no abs.
The SS ones do run pretty good from what ive read.
To be fair i think somethings going on with it. It runs good but when you stand on it to pass about 5000rpm it falls on its face and wont shift till you lay off it. Its throwing a cam sensor code but it has no cam sensor.
