- Jan 18, 2022
- 4.0 V6
I have a stock 2011 Ford Ranger XLT V6 4.0L, Front axel D028M, 3.73 gear ratio and 235/75R15's on it.
I've been doing research and I'm not having much luck on determining if I should stick with the 15in rims and go with a 30in tire or if I could/should go with a 16in rim. I'm not looking to lift it if I don't have too as of now. I'm just looking to get some better tires and looking rims since I'm on pavement and semi rough dirt roads 50/50. I don't do any hardcore off-roading so I don't necessarily need a huge amount of clearance but I definitely want something slightly bigger than what's on it now without my gears being extremely out of whack.
So my question is how much of a difference would it be from sticking with the same size rim in 15inches but going up in tire diameter from 29" to 30-31" but without the tire rubbing on anything or going with a 16in rim and possibly a 30-31inch tire?
Also is it better to go with a wider tire/rim or thinner?
The 3 types of tires I have in mind are:
1) Maxxis - Buckshot Mudder ll MT-764
2) Goodyear - Wrangler DuraTrac Radial
3) Falken - Wildpeak AT3 all season
I appreciate any help in advanced, Thank you!
