Curious Hound
Formerly EricBphoto
TRS 25th Anniversary
- Feb 7, 2016
- Age
- 61
- Wellford, SC
- State - Country
- SC - USA
- Other
- 2002 F250, 2022 KLR 650
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0 V6
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
Conduit is definitely not cheap. By RonD's numbers, 10 ft if 1/2" EMT is $9 + $7.50 for the wire. Plus conduit connectors, couplings and straps is well over $16.50 just to go 10ft.
BX or MC cable is really the simplest way to go and maybe the cheapest. Buy 250ft rolls to bring down the cost per foot.
You can also do a hybrid of romex and conduit. Stub a piece of EMT from your outlet box or switch box straight up the wall to get above ceiling height. Put a coupling and romex connector at the top. Run romex across the ceiling to the conduit and just stick it down the straight piece of conduit. You can strip the outer sheath from the part that is encased in conduit if you want. It's a very easy way to protect your wiring. And you can buy all romex instead of some rolls of romex and some rolls of individual wires. You must have the clamp where the romex enters the conduit. Again, buy your romex in 250ft rolls to get the price per foot as low as possible. You'll be surprised how fast 250 ft of cable disappears when wiring a home or shop.
