B4000 shift lever stuck in Park
Ragnar
5+ Year Member
Fredericton NB Canada
3" Body lift
LT265/75R16 .... (31s)
Was out in the woods with my 05 B4000 4x4 yesterday and stopped to take some photos and walk around a bit. When i got back in to leave, the truck started right up, but wouldn't come out of park. I crawled underneath to see if something had jambed the linkage and couldn't find anything wrong. I also could not move the linkage manually. After retrying starting and shutting off the ignition several times, the shifter finally came loose and i got out my situation. I just recently purchased this truck and have never encountered this in any of my vehicles before. Anyone have an idea of what is going on?
I can only guess that the steering whee;l lock was stuck in the twilight zone and the act of turning the ignition on and off several times brought it back into alignment - assuming of course that you have a steering wheel lock.
Sometimes when the steering wheel is sitting at an odd angle it will lock in a set position and not allow the lock to release without moving the steering wheel to free up the lock mechanism.
In either case you may want to pull the steering wheel/column covers and take a look at the locking mechanism.
DISCLAIMER: Other more knowledgeable folks will come along shortly with more definitive help.
Maybe that stupid solenoid/safety thing that requires you to step on the brake to get it out of “park”? Ive always hated that “feature “, along with auto-locking doors and seat belt dingers.
Solenoid/safety thing? Don't you always have to step on the brake to shift out of park on any vehicle ?
yes, since about the mid-90’s, its another thing that can fail, I bypassed it on dads 94 F250 years ago but don’t remember just how I did it, think I clipped the wire on the lock solenoid, this was the first automatic we had on the farm with that “feature” and it was annoying to grab a lever that wouldnt move then remember you needed to step on the brake. Our previous farm truck was a 77 F250.
BTSI... Brake Transmission Shift Interlock. Might be a GM term... but it's the one I remember.
Sometimes if you park with the park pawl loaded (think inclined or declined) you can have a little trouble pulling it out of park. That's why it's a good idea to set park brake in those instances.... takes the load off the park pawl.
This would be my guess
Considering I was parked on a level, I doubt a load on the park pawl was the cause. We even tried rocking the truck frontwards and back while I tried disengaging the shifter.
UPDATE : After asking questions in here and doing more research online I decided to replace the Shift Interlock Solenoid. The part cost me about 100 bucks Canadian. I am not a mechanic, however I am a retired aftermarket parts counter man, with some limited mechanical skills. I found a step by step video from 1A Auto on YouTube showing how to replace the solenoid on a 95-09 Ranger. It took me about two hours to complete and I thought, "Success". Tight quarters and a few choice words, got the job done. I thought the problem had been rectified. It shifted as required, when required! And no more locking up in Park. Drove it around for most of the day with no problems. 4 hours later, it's happening all over again. Locks up almost everytime I shut it off again, and after trying to restart it over and over, it sometimes will shift out off park. Obvious, It's not the Shift Interlock Solenoid causing this problem. A friend thought maybe it was the neutral safety switch causing the problem . At this point, I'm frustrated and at a loss of where to look next. I don't want to throw a whole bunch of money for parts if it doesn't solve the problem. Has anyone had this problem and how did you fix it ? Surely. I can't be the only one !! PS. Why do consul shift vehicles have an interlock bypasss on the consul, yet, a column shift vehicle doesn't? There has to be some way to bypass this system without replacing a bunch of parts that won't work !!!
There is a bypass in the column, it's a huge pain in the ass though
I found a temporary bypass that will work until it goes to the shop for repair next week. If it doesn't shift from park when you start it, turn ignition off. Put the Ebrake on, turn key to first click, push on brake pedal and pull the shift lever down to neutral. It will then start and shift into any gear.
That sounds like your transmission range switch is bad.
You put your one hand in
You put your one hand out
And you shake it all about
You put your one foot in
You put your one foot out
You do the hokey pokey
And you turn yourself around
That's what it's all about
Sorry. It sucks when technology fails us. I do hope that you get it repaired quickly and as painlessly as possible.
