I have a bit of a puzzle with my Ranger (1993 4x4 3.0L). It only crops up when the weather gets hot (like over 80 degrees). It will run as smooth as silk UNTIL I shut the engine down. After that it when you start it up it develops a pretty bad miss and runs rough. The miss does not seem to be consistent to one particular cylinder when I have pulled codes. If you let the engine cool completely, it will run perfect again and once it's running you can run it all day long like that without a single hiccup. Once it is shut down the same thing will happen. In cooler weather it never happens. As far as engine temp it does not seem to be out of the ordinary. Thermostat opens and closes, coolant flows and maintains a normal operating temp.
I have done the basic, cleaned MAF sensor, IAC, plugs and wires, checked for vacuum leaks and nothing seemed to make any difference. I wondered head/head gasket issues, but when I checked there was no combustion gas in the coolant (and I'm not loosing coolant) and I haven't had any of the classic symptoms. I compression tested each cylinder and had nearly even 150psi on each cylinder so again I don't see any indicators of anything amiss in one particular cylinder. I have read a bunch of issues related to fuel pumps but I wouldn't think that would be a repeatable thing that doesn't seem to get worse and only happens in a certain setting. I am thinking the next step is to start checking fuel pressure and maybe injectors and other fuel system components but I was just curious if this is sounding familiar to anyone. Thanks in advance!
