- Aug 11, 2008
Hi,
I have a 2002 3.0L Ranger. About a month ago it began having trouble starting. I would turn the key and it would take a second to turn over. The problem kept getting worse...ie..it took longer and longer to start. About two weeks ago it stopped starting all together....for the most part anyway. I took it to a shop and they replaced the CPP and the Master cylinder. They said the cylinder leaked and this made the switch go bad. I took it home, parked it, came back five minutes later and tried to start it. It didn't start. I took it back. They said the starter soleniod was bad. So they replaced it. Once again, I took the car home and parked it. It started a few times and then just as last time....it quit working. Any ideas? I'm tired of paying people to try things. The battery is fine. When I turn the key there is no noise. No clicking. Nothing. The power comes on. The radio, lights, everything works. The truck just will not start. I thought it could be the distributor cap.
Thoughts?
Thanks
Mike
Thoughts?
Thanks
Mike
