- Jul 18, 2008
- Age
- 37
ahh the old truck swallowed in a hole i remember
I had a strap, it's broken now... So whats the point?
Are you serious?
When a chain snaps it has enormous kinetic energy. Enough to kill a person. A proper strap will only hurt.
I wasn't referring to shock loads, if you treat your chain like that your in for a lot more than just a broken chain.Shock loads can make metal stretch alot more than you think. They also result in alot more energy being released very quickly.
I have found from many many wheeling trips that if you don't need to take a run with a truck to pull out another truck, that truck isn't all that stuck. The rare occasion that you are just on the edge of getting out unassisted is so rare I wouldn't carry anything for it. It's the equivalent of keeping a bulldozer on standby just in case. You will likely never need it. So the chain is still useless to me.I wasn't referring to shock loads, if you treat your chain like that your in for a lot more than just a broken chain.
Ease into it. Be gentle.
DO NOT USE STRAPS WHEN WINCHING
ALWAYS use a strap when using a tree as a winch point. If you don't you're not only causing damage to the tree, you're causing damage to your winch cable.
