- May 25, 2020
- Texas
- 3.0 V6
Pretty long post here so I’ll try to compress.
Last year, my 2000 3.0L FFV ranger was idling really bad and running really rich, even though both banks read “lean” when scanned for codes. After throwing plenty of parts and sensors at it and not changing anything, it eventually got worse to the point that it lost compression.
I took the heads off and decided to get them machined. At that point, I decided to take the rest of the engine out and do a full rebuild. Long story short, being my first rebuild, I didn’t blow the main cap bolt holes out after getting the block back from the machine shop, screwed a bolt in the hole to plasti gauge the crank, and stripped the bolt hole.
So at this point, I decided to ditch the full rebuild and grabbed me a 3.0L from a 2003 Taurus.
I stripped the Taurus engine down to pretty much the “short block”. Block, pistons, crank, cam, lifters, cam and crank sensors.
I transferred over from my truck the oil pan, intake, reworked heads, new timing chain for the ranger, new oil and water pump, and used the car pushrods and rocker arms. Pushrods were the same length as the truck rods. I’ve read of people using the same car cam in the truck and not having issues so I left it.
I got everything buttoned up this weekend and ready to start but it’s not starting. It’ll crank but wont start and sends a big cloud of what I’m assuming is unburnt fuel out the exhaust. Yesterday after work, I tried to start it again and got it to start for a couple of seconds by pressing the gas pedal all the way to the floor while cranking, which I’ve read shuts the injectors off as long as you hold the pedal. Once it starts, it backfires quite a bit and stays on for 4-5 seconds as long as I give it gas, then completely shuts off.
I have fuel at the fuel rail, even though I haven’t put a gauge to it. Certain I have spark. Have not checked compression, which I would guess I have some compression if I got it to start for a couple seconds.
I also ordered a FORScan adapter for my laptop along with the “license” to be able to use their software. It should be here next week. For now, I have my in-laws generic scanner wich only allows me to see codes and short/long term fuel trims as well as spark timing.
