James duff stage 1 lift
kcm94
Forum Member
Florida
So I finished installing the rear for my stage 1 3" James duff lift but I used 3" rough country leaf springs instead of the add a leaf for the factory springs the kit comes with. I'm starting the front tomorrow do you guys think it will level out? I figured using a set of leaf springs instead of the add a leaf for old springs would be better I'm just hoping it'll level out fine if anything i guess ill use the add a leaf. Just wanted some other opinions what do you guys think?
Well I can't really answer your question because I used a body lift on mine. But that does look nice and chances are it will look fine and if not you can try to fine tune it.
I used new rear springs on my lift 6” lift too. The end product still looks a little too high in the rear but she’s not complete yet. I still have no fuel tank or skid plate or spare tire so when all that’s done maybe she will look more level. IDK.
New springs is surely better than add a leaf. I think she will level out nicely.
kcm,
I don't believe that these vehicle should sit level unloaded. If mine did, I would add to the rear suspension, so that it is about level when loaded. +$0.05
I betcha it will level out fine. You can tweek it all sorts of ways if it doesnt.
Don’t forget, leaf springs settle. I learned that the first time I replaced leaf springs, thought I would get 1-2” over stock and when it came down off the jack stands the back was sky high. A week of driving it and the back was sitting where it was supposed to. So don’t panic until you drive it a bit.
OH yes! And don't torque until you have the vehicle on its own weight.
Been super busy so I haven't got to the front yet, will be doing it tomorrow and Saturday so I will post some pics when its finished. I'm pretty sure till level out nicely from everything you guys are saying I'm super excited I cant wait until its done! I have a dropped pitman arm on my parts bronco is it worth using that for the 3" lift? I'm taking the extended brake lines and the rear driveshaft from it to
I needed a drop pitman arm to get my steering angles correct. Mock it up and see how it looks. As far as I know, the rods should be just about level to be ideal.
ok cool I will for sure use it, if not it'll just sit there. Just picked up a super nice set of used 33x10.5x15 ko2s for cheap!! Gonna see if I can squeeze them on when I'm done with the lift. Might have to get the James duff body lift to put these bad boys on
I run 33x10.5 with a stage 1 lift without issues. Only issues are: 1.) at full lock I scrub the radius arm a bit (not a big deal), and 2.) I scrub the rear fender at the bottom front portion at full stuff offroad. I only need to trim a tiny bit to accommodate. For road use, it is fine.
68440
68441
Lotsa meat left on those tires, nice score!
awesome now I'm really excited! this is for road only so I guess I wont have a problem then! I got them for a great price I had to grab them
