fastpakr
⭐Supporting Member
- Aug 6, 2007
- Roanoke, VA
- Tire Size
- 285/75-16
How much commonality is there between the Vulcan short block and the Yamaha 3.0?Not really. Vulcan's didn't share much with any other Ford engines. You can mix/match different years of upper intake manifolds if you prefer aluminum vs plastic (this may require switching the lower intakes too, or drilling/tapping the bolt holes). Technically, flex fuel Vulcans should have slightly smaller combustion chambers (small compression bump) in their cylinder heads, but that went away eventually, and they all used the same heads.
