94 4x4, 4.0L coil spring replacement
rumblecloud
5+ Year Member
⭐Supporting Member
MI - USA
Vehicle
1-1/2 inch front leveling
Stock
What's the worst that could happen?
I've done some searching and found a couple of posts (also youtube stuff), but nothing really answers my question), which is:
is it just a matter of lifting the front suspension high enough until the spring just separates and can then be removed? I'm sure it isn't that simple - bolts will need to removed and there may be a tab or something that needs to be messed with, but is that essentially all there is to it?
I'll be replacing the shocks as well. If there;s link to a previous thread, that would be great.
I'm trying to decide whether to pay to have it done or DIY it,
thanks in advance.
r
It's been awhile... but I remember the shock... the nut and spring retainer on the bottom... push the beam down and turn the spring out.
I did a couple of these and never used a spring compressor.
Rust might be an issue so heat on the lower nut might help.
