- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
I got an Insignia 19" TV, cheapest set you can get, under 100 with tax. Seems nice. Picking up about 30 stations on-air with crappy antenna.
Here's what I want to do:
1. Long term project: Deep cycle marine battery, with inverter, fairly large, wire through fuse box, and use that to power devices. Most inverters have USB charging ports as well which is nice. That would be a permanent-type installation. It would isolate the truck's battery so I wouldn't worry about not being able to start the truck, plus, assuming the deep cycle battery had juice, it would be a backup for starting just in case. How to charge deep cycle battery? a) trickle charger, at home, when it's getting low or b) have a cutoff switch so it would charge via truck's regular charging system, but, when using it, open that switch so as not to discharge truck's battery or c) maybe, solar charger on roof for it, but, so far what I read about these is sketchy, so, probably wouldn't go that route. In this future setup I'd have a pretty good size inverter, maybe 1k watts or something like that, if I were doing it, might as well do it right. Wiring would be permanently installed and hidden so far as that can be done.
2. Short term project: TV takes .8A @ 120 so that translates, I think, to 8A@12V (corret me if I'm wrong there). At this point I only want it for short use, like, I have to be one place, then another place, and instead of driving home then driving again, I just go to second place and watch the news for a half hour or something. Just a way to kill time, save gas, and not be bored. So short term I'm thinking just one of those inverters that plugs into the 12V Aux on the dash would work. I hate cords hanging all over the place, but just to start, that could work. Something like maybe 150 watts inverter should be ok (again, correct me if I'm wrong there.
3. Additional features.
a) rather than install expensive Nav/stereo and replace existing OEM stereo/CD, which works fine, if what I really want is the Nav part, I -should- be able to output from my Alcatel phone's USB port to the HDMI input of the TV. The TV does have USB input, and that works from the phone, but it expects to see a directory of photos, that's nice, but not what I want. I am thinking, and here's where I need advice, there are adapters USB to HDMI so I am thinking that if that works, then, I would have Nav, because I could go to Google maps on the phone, and then see it on the TV, and it would be massively big compared to what fits in the dash. https://www.bestbuy.com/site/insign...mini-hdmi-cable-black/6186216.p?skuId=6186216 is the adapter. So if someone has done this (phone to HDMI on tv), or knows about it, or, I just buy it, try it, if it doesn't work, take it back. It would be awesome if it worked. Casting from phone to tv would be an option but, then we are talking different equipment altogether because I think neither my phone nor tv can do that. Probably with an Apple phone and a Jensen tv you could do it, but I'm not going there.
b) input sound from the TV and/or phone to the truck's stereo. I'm using the tv in my shop, with sound output to a regular amp/speakers, that works great. However the OEM stereo, I'm not sure how I would get that to work. Newer vehicles have a place you can plug in aux input, but my truck doesn't have that, unless I've missed it somehow. I'm wondering if I could simply install the aux port, how they usually work is if it's plugged in, the stereo chooses that. I don't know if it would be simply a matter of wiring it to the OEM stereo, or, if it's simply not possible. That is just for sound, but you can see how then when you watch tv you can have the sound through the truck's speakers, or you can listen to music from the phone, etc. I know nowadays there is Bluetooth and so on but without a major upgrade to stereo (read: expensive) I'm not thinking in that direction. As far as, does the basic idea work, certainly I could try it on another vehicle here that does have the audio aux in port, I imagine it would work fine.
As to the tv in the truck, it's small, no problem fitting it, or taking in/out so it can do double-duty in shop and truck, and ultimately I'd probably want some kind of arrangement where it could flip down or something and be held securely when not in use. Obviously one does not watch tv (but Nav, yeah) when driving. Usually new systems wire through the park brake sensor or trans park position sensor so it disables tv if not parked, but I don't need that, I'm not dumb enough to try to watch tv and drive at the same time. But say you were stuck in traffic on the interstate waiting at a standstill for an hour for an accident to clear. It'd be pretty nice then for sure.
I sure appreciate any help you all can give me on this.
