fastpakr
⭐Supporting Member
- Aug 6, 2007
- Roanoke, VA
- Tire Size
- 285/75-16
I've had an '01 Sport Trac axle floating around for quite a while and it's finally time to swap it into the '99 Ranger. Spring perches and shock mounts are moved and there's a new Torsen all set up inside. However, at some point in the last few years I misplaced the hard brake line for this axle. Does anybody know if the hard line on the 7.5" axle will work as is? I'd love to be able to reuse that when I remove the old axle if that's a possibility. The Sport Trac is a drum axle, so it should at least be -close-.
