- Aug 2, 2021
- Merced, CA, USA
- 4.0 V6
I have a 1996 manual transmission 4x4 ford ranger 4.0L V6. Last night I attempted to ford a creek, but decided to turn back when the water began to reach the doors and cover the bumper. As I decided to turn back I stalled from letting the clutch go too suddenly. The truck sat in the water with front differential and lower half of engine submerged for about 15 minutes while I decided what to do. The engine struggled to start a bit and ran a little rough for about 3 seconds as I gunned it out of the creek in reverse. I let the engine idle for about 3 minutes after getting back on solid ground and It drove fine afterward. water reached about 3 inches below the air filter housing. I assume the engine drew just a little water in, hence the rough start and running rough for a few seconds. I take it a small ammount of water entering the hot engine vaporizes instantly and is now a compresible gas just like air/exhaust. should I change/inspect the oil , transmission fluid , and front diff gear oil ?
