Replace both my clutch master cylinder and slave cylinder in my 1989 Ranger. Bench blood the slave master cylinder and got all the air out of it. Once I reinstalled the master cylinder I cannot get the line into the slave cylinder. No matter how hard I push it will not go into the fitting at the slave cylinder. I have eliminated miss matched parts as the problem. The only thing I can think of is because I bench bled the clutch master cylinder it is under pressure and that pressure is not letting the line go in to the slave cylinder. I don't want to drain the clutch master cylinder to take pressure off because it is a bear to bleed after being hooked up. So any help would be greatly appreciated. Thank you Jim Wright.
