I need help determining what wires to jump to bypass the nss on a 2008 automatic ranger.
I brought it up because that was the behavior I've experienced in the past - flaky start in park that could be worked around by holding the lever slightly out of position (and sometimes starting in neutral helped). No codes or apparent drivability issues.The problem is with a range sensor out of adjustment is that it does not just effect neutral. That sensor sends the computer info on all gear positions so it will throw error codes and cause a bunch of wacky transmission problems.
