- Feb 28, 2001
- Dayton Oregon
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
My friend that's a general mechanic also does mostly transmissions and is NOT a fan of the 5r55 trans, it's just an update on the A4LD from what he says... the 4R70W on the other hand that's in my Explorers he doesn't have any problems with other than we should have just used my original trans as a core since EVERYTHING inside it was worn out...
He's also mostly a GM guy but knows everything has it's ups and downs, when I said I wanted to build a V8 explorer he scoffed a bit but didn't complain too much when I had him build the trans, he said he wouldn't have supported it if it had a 5r55...
One of the downfalls is likely the squishy shifting to please soccer moms, I'm sure they would last longer if they had a shift kit and solidly shifted between gears...
