- May 28, 2018
- 41N 75W
- 2.3 (4 Cylinder)
- Total Lift
- It's up there.
- Total Drop
- It's down there.
- Tire Size
- Round.
- My credo
- I poop in the furnace.
WU-TANG FOR LIFE SON!
Ha! Had to look that up. You kids and your "music".WU-TANG FOR LIFE SON!
Sounds more like "WU-TANG FOR DEATH!" to me.Wikipedia said:On November 13, 2004, Ol' Dirty Bastard collapsed at Wu-Tang's recording studio [...] and was pronounced dead later that night.
Any updates on your issue? I'm tired of working on mine so I figured I'd troll post to see if I could help or at the least keep it bumped. My first suggestion is compression test. Also check the inertia switch. If you happened to have hit a bump really hard or something hit the truck just right it might have tripped it. Thirdly, check your relays and fuel pressure to make sure they are working. Fourth, fuel pressure test if you can. Since it was running fine, but now won't start more than likely not getting fuel....Thanks for the help. It turns out some squirrels decided to eat the fuel lines. I ended up having to replace all of fuel lines and the pump. Everything was working fine and then after it sitting for a few days I took it on a 100 mile drive. During the drive whenever I stopped at a light there was a bit of a puff of white smoke that looked a bit like steam. This was not a large amount but still enough to get my attention. There was no sign of any heating or a noticeable decrease in power. On the return drive there was not more white smoke and it was driving normally. Now after the drive it wont start. It turns over but its just not starting. I checked again for any signs of fuel leak and there are no signs of that. I have also taken some precautions to scare aware away the rodents...
Any thoughts on what this might be? All of the fluids including radiator seem fine.
Thanks again for any tips.
