- May 10, 2021
- Waukesha, WI
- 3.0 V6
97 Ford Ranger XLT 3.0 V6
I have no cold A/C. The heat works, but on full cold it only blows ambient temperature. If a little warmer.
I checked the low pressure switch, and there was continuity (not 100% sure I checked the correct plugs since there are four, but there was continuity between two of them.)
When I poked the Schrader valves on Hi/Lo sides, there was absolutely nothing. The low side gave a tiny little baby hiss, the high side absolutely nothing.
[May be a red herring, but when I was tinkering with the A/C once, I heard a hissing sound? from the dashboard. Could this be a sign of a failed heater core?]
Where should I start? (can I pressure test the system with air?)
