Hello all,
I come to you again with a request for aid. 1985 2.8 ranger with a duraspark conversion wired exactly per the guide.
Using an in-line spark tester, I have no spark starting at the coil to distributor. I have 12.5 v going to coil from module in run and 10.5 in start. I have a wire going from the starter relay "I" to the coil in addition because I thought it might need full voltage at start. I have tested the pickup in the distributor which checks out. I've also tried swapping ignition modules with no change. I've checked all of my harness for continuity and it checks out. Battery at full charge and tested. New battery terminal wires and a ground strap.
I kept the original coil from before the conversion because it was less than 2 months old. Could this be my issue? Any other ideas?
