- Aug 6, 2011
- 4.0 V6
- Total Lift
- 2"
Has anyone had trouble with the Comp Cams 410 cam on the stock EEC-V computers? After a few minutes running my rebuilt motor it's incredibly rich, pouring fuel out the exhaust.
I just reassembled my '95 block with new rings, new rod bearings, new lifters, pushrods, and rockers. Reman heads with stock valves. The rest of the motor is otherwise stock/original except for the upgraded cam with a new timing set.
It first started last night and seemed smooth, but this morning under any load it stumbles and hesitates horribly. I found a fuel leak around one injector, so the upper intake came off and I put on new injector o-rings. Spritzed carb cleaner all around the intake, egr, vacuum lines, throttle body, etc, and found no vacuum leaks. Vacuum gauge reads 18-20 psi at idle.
I took it out on the back roads for a 10 minute test drive, and eventually got a code - "P1131 – Lack Of HO2S Switch – Sensor Indicates Lean". Shortly after I got another code that indicated rich on the other cylinder bank.
I backprobed the MAF sensor and it's returning 1.2 volts at idle, 2.6 volts when I blip the throttle, and seems to scale with throttle input. My scan tool live data reports sane Intake Air and Coolant temps. O2 sensor voltages are .3-.4 volts.
What's weird to me is the live PCM data is indicating a Short Term Fuel Trim of +42% which appears to be extremely high, and corresponds with the rough running and fuel out the exhaust.
Does anyone have any experience with this? Does this sound like bad O2 sensors? or bad MAF?
