accelerator pump
Rammunition360
farmersville, ohio
so i changed out the whole acc pump on the ranger an hour ago and i was wondering if the throttle link was supposed to touch the button??? It touched at WOT but i thought it was closer on the old one??? The bar is about 1/2" away from the button, can anyone clarify if it is supposed to be that way?
well i put the big end of the spring at the acc pump and the little end at the carb...and i didnt take the linkage apart? and it wouldnt bolt on any other way than i got it, unless i wasnt paying attention haha which could very well happen haha
Is the button protruding 1/2"?
see i thought so to but i didnt change it, i unscrewed it and screwed it back on...is it possible to bolt it on wrong???
Not really.you have several holes that the linkage plastic pivot can go in on throttle.Did you have it loose?
is the button the same length on both the old and the new pump? Could be you have the wrong pump.. If not then it is operator error..
Big Jim
yeah its the same length but i didnt touch the throttle linkage...unless someone fiddled with it while i was at the parts store...and i was sober the whole time. I went out and studied it tonight and came up with nothing so i am going to take the acc. pump back off and examine it closer in the morning
