Djm dropped v8 rangers ..come on in.
Junglejoe
Columbia Missouri
Looking for those who used the 4/5 or 3/4 drop..
Can I get some pics and feed back on ride quality and if there is alignment issues...
I plan to do a v8 but not to that point yet. I have the 3 inch drop beams up front. I did the 4 degree cam bushings something you want lowering it. I also did the front brake upgrade so I had the bracket machined to run the bigger 12 inch rotors off the 2004 sport trac explorer.
You will definitely have alignment issues without the 4 degree cam bushings forgot to add that
I appreciate the info. Mine is a coil spring, 2000.
Thinking more ing the lines of 3/4 or 2/3 then. I will be useing the truck to sometimes pull a small motorcycle trailer.. so it has to be practical
Id say at 2/3 3/4 should work for you either way but I have no experience with the a arm type front ends. I would imagine it should be pretty straight forward.
