- Mar 9, 2016
- Columbia Missouri
Anyone know the best place for the o2 sensors? Getting the exhaust done finally with new pipes from the headers back..
That far down you need to run a heated sensor if you are not doing so now. It needs to get very hot to work correctly. The factory used heated O2 sensors for the same reason, so they warm up and work as quick as possible.In the headers wont qork for me.. so after the collector it is.
And put the bung so O2 is accessible once pipes are in place![]()
This statement is absolutely absurd and goes against all known engineering practices.
Yes.. ONLY front o2's . The downstream was deleted. Im on a "start up" tune at the moment so I get it lined out before it hits the dyno. But Bob here in Missouri @ STL Mustangs is tuning it@Jungle joe, are you only using 2 o2s? who did your tuning?
