Need help with a issue
Pensacola
I have a question my 2001 Ford Ranger 3.0 cranks then dies it runs idled high then dies and runs very rough ...I replaced the Fuel Pump and Filter ,EGR valve and EGR sensor ,Cam Shaft Position Sensor and Synchronizer ,Crank Sensor ,and Coil Pack trying to track down the problem but its still doing the same thing it runs for about a minute then shuts off ...Can someone please help me "Thank You
Will it stay running if you hold your foot on the throttle?
Im beginning to think its a wiring issue ...when it started I was on the interstate and the oil pressure gauge started jumping like crazy and soon as I hit 70 the engine would slowly start slowing up and start running rough then it shuts down you cant give it gas to keep it running
Pull codes like they said. But also, check battery voltage key off and engine running.
