1989 ranger Idle issue
Michigan
I have a 1989 ranger 6 cyl runs rough at idle. Idles up and down. Any advise
Thread moved to the general section since I don’t know what V6 engine you have. Please give us more details. Help us help you.
Yup, like Sarge said, with info, we can help out.
Have you pulled trouble codes?
I believe you can pull blink codes. I involves using a jumper wire in a connector but it has been so long since I've had to worry about that kind of thing I forget the details and what years you could use it. One of the members that have more recent experience your year range would have to expound on it.
I've moved the thread to the 2.9 Sub forum for continuity and so if others run across a similar issue with their 2.9s, they'll be able to easily find it.
Yep, there's an article on here. Use a paperclip, write down the codes, look em up, report back. We shall consult the runes. :icon_thumby:
@RonD, @rusty ol ranger
Or spend the 25 or 30 bucks and buy this bad boy...
I bought this and it makes it much eaiser and foolproof to pull codes, espicially if youre new to it.
