Guanfy
- Jun 22, 2019
- 3.0 V6
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- 15in
So I noticed on my test drives after the swap that I was getting clunking. Upon further inspection I identified the rotor is clunking because the rotor holes are a little oversized compared the to lug studs. Normally this isn't a problem as the rotor hat gets compressed by the lug nuts and locks the rotor in position. However... even when torquing open lugs at 100 ft-lbs the rotor is still clunking freely. So to the others on the forum who have done this, did you have this same issue? Was your solution to use spacers to make up the difference to lock the rotor hat in place? Did you use a wheel spacer to convert it to lug centric? I bought decent rotors new for a 2000 Mustang v6, which should be compatible with this mod. The axle they are being bolted to is a 2007 ranger 8.8 axle.
