- Jun 30, 2013
- AZ
- 4.0 V6
anymore I hate anything to do automobiles other then driving them.
Yeah, those are nice,Amazon.com: Mityvac 7201 Fluid Evacuator Plus: Automotive
Buy Mityvac 7201 Fluid Evacuator Plus: Fluid Evacuators - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Everything is heavier the older I get....Im considering a forklift for things like tire rotations, or carrying a sheet of plywood.Rotating tires... the older I get the heavier they seem.
On my F150 I disconnect the line and pump the fluid out (carefully), which drains it enough to drop the pan without a mess. I saw a youtube video on it. I was able to give it a good flush this way adding fresh fluid as it pumped out as well. Worked great and solved a slight shifting issueYeah, those are nice,
BUT...
Without dropping pan, can't clean pan or change filter...
Unless someone's come up with a way to do those thru that itty bitty dipstick tube.![]()
Where's the fun in that ?On my F150 I disconnect the line and pump the fluid out (carefully), which drains it enough to drop the pan without a mess. I saw a youtube video on it. I was able to give it a good flush this way adding fresh fluid as it pumped out as well. Worked great and solved a slight shifting issue
WTF? Who does that?Washing/detailing/waxing the frame/chassis/underside of the body and bed. Pain in the arse to lie on your back doing all that stuff !!!
What,, you mean you guys don't wash/detail/wax the undercarriage of your Rangers ?WTF? Who does that?
Here. I'll fix it for you and it will fit me.
"Washing, detailing, waxing vehicles"
I do all that stuff.What,, you mean you guys don't wash/detail/wax the undercarriage of your Rangers ?
Oh, for shame !
I'll bet you all don't even remove the seats when you vacuum.![]()
If you have a lease and a warranty, you don’t need AAA... The tow is covered by the manufacturer.Sometimes I would gladly trade all those tools and times and struggles and crap to be the regular Joe Blow with a AAA card, a warranty and a lease.
Why would you rotate the tires ?Rotating tires... the older I get the heavier they seem.
As long as you use your phone call to call up and say the truck is broken.Even if the vehicle had to be towed from an Arby's parking lot after you were arrested for rubbing your junk on all the packets of horsey sauce?
