helpful tip about PS pulley removal
pjtoledo
⭐Supporting Member
Toledo Ohio
the metal band just didn't have the guts to hold the 2 halves together, they started to slip off,,,
well, that wasn't going to be tolerated.
43207
in the end, I won!
2000 3.0, first time off.
wonder if a hose clamp would have sufficed?
my puller is a little different then that one... I've never run across one it would pull.
either way pj… way to git er done!
in the end, I won!
O used a hose clamp when I did mine. Worked great. The metal band is useless.
AJ
I do not envy you rust belt guys... never had a problem using top quality Harbor Freight puller...
I have never had a problem using local auto parts rent-a-part puller.
